NI 6251 too many physical device names?
the USB NI 6251 BNC should have 8 digital I/O ports, named PFI0..PFI7, but the drop down list consists of 16 possible items.
system: Win7 and debian stable
(3,372 Views)
The 6251 has 3 ports or 24 lines. I have no idea how you only see 16. I see all 24. If you want to select ports, lines, or both, you right click on the channel constant and select I/O Filtering.
(3,364 Views)
what is the difference between port and line?
(3,361 Views)
and is PFI12 the same like USER1 on the terminal?
Where can i find a table with the naming scheme?
(3,359 Views)
 A port is multiple lines - typically 8 lines in a port.
Refer to the manual.
(3,353 Views)
