NI 6343 multi analog out signal
I have to control 2 differents analog output.
Thoses two output are used to control two motors.
I have to change value of voltage at differents times.
For example motor A voltage should be:
- 1 during 4 seconds
- 2 during 3 seconds
- 3 during 5 seconds
- 4 during 7 seconds
- 5 during 1 seconds
Motor B should be :
- 5 during 2 seconds
- 4 during 2 seconds
- 3 during 8 seconds
- 1 during 5 seconds
I am using nidaqmx python lib, actually i'm able to control one motor, and changing the value of analog output with the following code:
        with nidaqmx.Task() as task:
            task.ao_channels.add_ao_voltage_chan(port)
            task.timing.cfg_samp_clk_timing(
                8000, sample_mode=AcquisitionType.CONTINUOUS
            task.write(y[i])
            task.control(TaskMode.TASK_COMMIT)
            task.start()
        while timer:
            if time.time() - le_temps >= temps[i]:
                print("STOPPP")
                print(time.time() - le_temps)
                timer = False
This code works well, but when i try to use it in differents threads to run it simulteanously with above code:
t1 = threading.Thread(
    target=moteurs.gestion_amplitude,
    args=[FREQUENCE_A, reglages_ampli_A, t, "Dev1/ao1"],
t2 = threading.Thread(
    args=[FREQUENCE_B, reglages_ampli_B, t, "Dev1/ao2"],
t1.start()
t2.start()
t1.join()
t2.join()
It doesn't work, i get an error:
nidaqmx.errors.DaqWriteError: The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<1>
Status Code: -50103
Does someone has an idea of how to do this in a correct way ?
Thank you for help !
Message 1 of 1
(891 Views)
