NI 6358
Hello Everyone .I m using NI 6358 multifunction card to generate analog output from channel 0  from the MAX . the problem is when i send any o/p voltage, It is sending not more than 3.37 V. can any one tell what exactly the problem is .Other 3 Channels are working fine.
(3,073 Views)
What do you have hooked up to the output?  What is the load?
(3,072 Views)
there is no load connected .i m using DMM to view the output from MAX.
can i use DAQ diagnostic utility to kno what exact the problem is?
(3,052 Views)
