NI-8234 Dual Gigabit Ethernet Interface for PXI Express
Hi
I am using a NI-8234 Dual Gigabit Ethernet Interface for PXI Express.
I am unable to find in which slot of PXI-1045 chassis it is Plugged-In.
I need a way by which I could find that the slot number of this card.
Please help me with this.
Regards
Ashish Paralikar
(3,210 Views)
Go to Measurement and Automation Explorer and expand My System>Devices and Interfaces. You will detect your PXI 1045 there and under it, you can see a list of modules currently connected and configured to your PXI system with their respective slot numbers. Additionally, you can also visibly detect the slot number. The left-most slot is called the slot1 and is reserved for the PXI controller and the slot number increases as you go towards your right, and a number is printed below every slot.
(3,196 Views)
Hi
Thanks for your reply.
but, as NI-8234 is a ethernet interface card, it is not visible at the place you mentioned.
All other DAQ cards can be seen there.
Ashish Paralikar
(3,181 Views)
