NI-8452 SPI script latency reduction
I am looking to control an external SPI switch device as part of an aquisition system.  The basic state machine is, setup switches -> make reading -> change switches -> make reading...  The reading is made by a PXI DAC ADC combo however the switches and signal conditioning are housed in a custom piece of equipment controlled by an NI-8452.  There is a connection between the PXI and DAQ to start the aqisition as soon as programming is complete.
I would like to reduce the latency of the state machine as possible.  Is it possible to preload a script into the DAQ, for example?
Message 1 of 1
(2,891 Views)
