NI-9203 Current Measurement Noisy
I am attempting to use an NI-9203 to read a 4-20 mA signal from a pressure transmitter; however, I am facing significant noise for my applications (± 0.1 A). This is causing a large noise in my pressure measurements, which I need to eliminate for my application. I have attempted shielding all wires, but it did not make a difference. I also checked the current from the sensor via a multimeter and placed a resistor in the loop to measure the voltage drop across the resistor and back-calculate the current from there, and both of these measurements are very stable, thus, I believe the issue lies in the data acquisition side, not the sensor. Any recommendations for this issue would be greatly appreciated.
(1,051 Views)
This article from NI may help with the noise in your measurements:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RcsSAE&l=en-US
(925 Views)
