NI 9207 Calibration Procedure
Is it possible to calibrate the NI 9207 using Visual Studio instead of LabView? I cannot find the function calls mentioned in the manual in Visual Studio, like "DAQmxGet9207CalAdjustPoints", "DAQmxAdjust9207Cal", "DAQmxAdjust9207OffsetCal" and so on.
(2,932 Views)
Hi peterjo,
What programming language are you using? Those functions are declared in NIDAQmx.h which is for C or C++. If you're using VB.net or C#, you probably want NationalInstruments.DAQmx.ExternalCalibrationSession.Get9207AdjustmentPoints() etc. so you don't have to P/Invoke all the DAQmx entrypoints.
If your copy of NIDAQmx.h doesn't have those functions, then you need to upgrade to a newer NI-DAQmx version.
Brad
Brad Keryan
NI R&D
(2,926 Views)
