NI 9207 only reads 2 of the 5 wired current input channels
Hello
I have a NI cRIO 9076 with two NI 9265 analog input modules, one NI 9482 relay module, and one NI 9207 analog input module. The NI 9207 module has 5 lines wired into current inputs. There is also an external supply voltage of 24 volts supplied to the module. The module is used to read data from three flow meters, a pressure gage, and a flow meter. The first two current inputs from the first two flow meters reads correctly, but the last three do not read anything. I am not sure what the issue is. Any ideas? Thanks for your help.
(4,464 Views)
Hi Leroy,
Are you trying to read the AI channels all the same way? How are you verifying your data/lack-of-data?
David H.
(4,438 Views)
