NI-9210 input channel TC1 not functioning?
I have an NI-9210 thermocouple 4 ch DAQ module inserted into a cDAQ-9171 chassis and channel TC1 does not seem to be working. I can insert thermocouples in to TC0, TC2, and TC3 and test in Measurement & Automation Explorer and they all output and respond correctly. I can then move one of the working thermocouples to channel TC1 and I get a temperature output around 2382 that slowly drifts in one direction. I have all settings set identical to other inputs that work fine. For these tests, I set the CJC source to build-in. The output on TC1 seems to be related to this CJC value. When I set the CJC source to constant I get a constant output near 2380. When I change the measurement type to voltage I get a constant voltage output. It's like my TC1 is shorted or otherwise defective.
Is my channel TC1 broken or do I have a setting wrong?
Thanks.
(2,546 Views)
This may be a hardware issue.
Are you using the spring terminal version or the Mini-TC version of 9210?
Your TC1 channel connector maybe a little loose or too tight, causing the voltage to drift too high.
You may want to contact your local NI office to get the device RMA'd.
(2,491 Views)
It is the NI-9210 version with the Mini-TC connections.
I'll contact an NI rep and try to report back to this post with the resolution.
(2,473 Views)
