NI 9211 sampling rate
I am using NI 9211 together with cdaq NI 9717. I wonder what is the meaning of 14S/s "aggregate". As stated in the datasheet that the sampling rate for NI 9211 is 14S/s which also means the conversion time is 70ms per channel, but when I tested in the NI MAX by input "14Hz" in the timing setting , it shown with an error message: Error -200332 occurred at DAQ Assistant.
Possible Reason(s):
Specified sample rate is higher than the fastest rate supported by the device.
Property: SampClk.Rate
Requested Value: 14.0
Corresponding Value: 14.000002
Maximum Value: 7.142857
which make me curious about the maximum value on the sampling rate, shouldn`t it able to run 14S/s, instead of 7.142857S/s
Could anyone please explain the function of "aggregate" or suggest the corrective action. Thank you very much.
(1,303 Views)
Accepted by topic author GracelynnMa
Hi, the answer to your questions is explained on this KB: What "Maximum AI Sample Rate Single Channel and Aggregate" Values Means?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIz9SAE&l=en-US
(1,255 Views)
