NI 9215 pin out
I'm using a NI 9215 with BNC connectors on a CDAQ-9171 chassis and am trying to make a cable to adapt from deutch ASL to the BNC on the 9215. I have the pinouts for the ASL connector, I just need the BNC pinouts. Is it just a standard pinout for the BNC or is it different for this unit?
(3,972 Views)
Hi mkatsiou,
Thanks for posting on the forums!The BNC pinout will likely depend on which BNC cable you are using. Do you have the model number handy?
Tina K.
Applications Engineering
ni.com/support
(3,950 Views)
