NI-9217 RTD input accuracy in relation to ambient temperature
Hello.
I have a question concerning the accuracy specification of the NI-9217.  Curious if NI or someone else has more detailed information about the accuracy specifications.  The specification for the NI-9217 states for a 3 wire configuration (which is quite good):
Measured Value      Ambient 25C    Ambient -40C to 70C         20C to 30C
-200C to 150C        0.20C                0.5C                                   ???
Interested if NI possibly has a graph/data that might suggest what the accuracy might be in a laboratory temperature environment.  Would be an additional column to the datasheet 🙂
Dan
Not really a problem. Just curious if NI can provide more accuracy information. The NI-9217 datasheet specifies:
For measured value -200C to 150C
Typical 25C: Accuracy 0.2C
Maximum -40C to 70C: Accuracy 05C
In our applications, the NI-9217 will be used in a Lab enviorenment that will be typically 20C to 30C and are measuring ranges between 0C and 100C. Is there possibly a graph that can be disclosed that shows accuracy over different ambient temperatures?
Dan
(2,816 Views)
Hi Dan,
I do not think that we have a graph with the data for different ambient temperature, but from what your description implies (ambient temperature of 20-30C measuring 0-100C) the accuracy should be pretty close to 0.2C. The slight fluctuations in the ambient temperature should not effect the accuracy enormously 🙂
NI 9217 Datasheet: https://www.ni.com/docs/en-US/bundle/ni-9217-specs/page/specs.html
Hopefully this helps!
(2,784 Views)
Maura:
Thanks for the information.  I agree that with minimal ambient temperature change the accuracy should be similar to the typical 25C.  Was just looking for some data to back up that thought.
Dan
(2,778 Views)
