NI 9219 and Pressure - Temperature connection
Hello.
I have a question regarding how to connect the following sensor to NI 9219.
See attach file for the sensor spec.
I will like to read both Pressure and Temperature at the same time using NI 9219.
Also is it possible to use only 1 channel for both signal or do I have to use 1 channel for each output?
Thanks in advance.
(3,822 Views)
bump
(3,800 Views)
Hi there,
I am now currently using the same sensor withthe NI DAQ 9174 and I am hving issue getting the reading if the temperature out. Could you please share with me on how the wiring was hooked up to the NIDAQ. I am using the MAX software to detect the temperature changes and the temperature is currently behaving like a resistance and flatlining at 10.5K.
Thanks for your help.
(3,411 Views)
