NI-9221 DSUB not recognized in MAX
I see my NI-9221 DSUB in "Device Manager--System device--Universal Serial Bus device" as "BillBoard Device" when I connect with its USB--DSUB cable.  However, I didn't see it was recognized in MAX even I do "create new" at Device and Interface.
I download NI-Serial, DAQmx, and NI Device driver, reboot PC, none of them help. I also tried to do "Hardware Configuration Utility" in MAX.
Can someone help? Appreciate it.
(604 Views)
Is your NI-9221 installed in a USB-9162 carrier?
Based on the green icon of your NI MAX, you have a driver version that is 2020 or later.
According to Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT, USB-9162 is last supported in NI-DAQmx 17.1
https://tmesystems.net/
(571 Views)
I have "cDAQ-9171, CompactDAQ Chassis (1 slot USB)" which was suggested by NI.
Attached is what it looks like.
(545 Views)
