NI 9223-" unsupported cDAQ module" when moved from one pc to another
I am using a NI cDAQ-9188 with NI 9223, NI 9220 , NI 9237, NI 9235, NI 9214  .
When I run them using a NI-MAX version 15.3, they all work.
When I try to run them on a NI-MAX version 5.5 ,the NI 9223 module comes: "unsupported cDAQ module".
Is it because the NI-MAX version or is there any other reason?
Thank you.
(3,510 Views)
Please see this link:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P71bSAC&l=en-US
Your Daqmx Version 5.5 doesn't support your module.
kind regards,
Lily
(3,492 Views)
The NI-MAX version doesn't matter so much, but the NI-DAQmx version does. (Within NI-MAX, the version of NI-DAQmx can be seen under My System→Software in the tree.)
If the installed version of NI-DAQmx doesn't support a module, it will appear as a "Unsupported Module" in MAX. As per https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac..., the NI 9223 with Screw Terminal requires at least NI-DAQmx 9.2, and the NI 9223 with BNC requires at least NI-DAQmx 9.9.
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(3,476 Views)
