NI-9263 783740-01 vs 779012-01
What are the differences between the two NI-9263 modules?
https://www.ni.com/en-us/shop/model/ni-9263.html
All the specs appear to be the same and the prices are the same.
783740-01
NI 9263 Spring Term, +/-10 V, 16-Bit, 100 kS/s/ch, 4-Ch AO Module
$455
779012-01
NI 9263 Screw Term, +/-10 V, 16-Bit, 100 kS/s/ch, 4-Ch AO Module
$455
Thanks!
(3,092 Views)
One is a spring terminal and one is a screw terminal.  You have it listed in the description you posted Smiley Wink
So just different options on how to connect the wires.
(3,073 Views)
wow! i totally read spring and screw as the same word. thanks for pointing that out!
(3,069 Views)
