NI 9263 stopped working
I have a NI cDAQ 9174 which I'm using with an NI9215, a NI9263, and a NI9227. Recently, all of the channels but one (Channel 3) appear to have stopped generating any signals. I'm pretty sure I set up the tasks correctly, as I set them all up the same way and one of them does work (also, Channels 1 and 2 at least used to work as well).
Does anyone have any idea why this might have happened?
(5,058 Views)
Trevor.Apple,
There's not enough information to proceed with.  What have you tried so far?  Can you cycle through the channels in your VI?  Have you verified the channels in MAX?
Wayne T. | Application Engineer | National Instruments
(5,012 Views)
Yes, I verified the channels in MAX. I've used channel 3 both in MAX and my VI, which is a pretty simple VI using the DAQ assistant. When I try to use the other channels in the same way, nothing happens.
Not sure what you mean by cycling through the channels in my VI.
(5,010 Views)
I would hope that you are using a single DAQ Assistant.
Since the channels work in MAX, the problem has to be in your code. Since you did not attach it, pretty hard to determine what you did.
(5,004 Views)
Using a single DAQ assistant, yes. I miscommunicated however, the channels do not work in MAX, so I suspect the problem is not with the code. That's why I didn't attach it.
(5,001 Views)
What did you have the channels connected to? Are they disconnected now and you still can't measure an output?
Might be time to contact NI for an RMA.
(4,995 Views)
I previously had channel 1 connected to the line on an IC which enables the on chip voltage regulator. Channel 2 connected to a switch circuit which sets a digital output high or low depending on the input voltage. Channels 3 and 4 had perviously not been connected to anything until I started testing them this last week.
I also disconnected from the everything in order to verify that Channels 1, 2, and 4 weren't working.
Thanks for the suggestion; I'll submit a support request.
(4,989 Views)
