NI-9265 not outputting desired samples per channel
I'm using one channel on NI-9265 to output multiple values. The sample size is 100 and and my clock rate is 10kHz. Using the Daqmx property node to display Total samples per channel generated, it sometimes states that only a few (14 or 15) of the 100 samples had been generated. Has anyone seen this issue before?
Dan
(2,568 Views)
Yes, usually due to wrong coding 😄
Your vi?
Greetings from Germany
Henrik
LV since v3.1
(2,543 Views)
Hopefully, it is something wrong with my programming.
Thanks.
(2,537 Views)
An observation I just made is that when enabling highlight execution, all of the desire samples are written. Could this mean I'm missing a delay somewhere?
(2,535 Views)
Accepted by topic author Dan_OD
Just needed to add in the Wait Until Done vi. Fixes the issue.
(2,534 Views)
