NI-9266 calibration
Hello everybody,
I would like to know if it is possible to perform NI-9266 calibration with cDAQ-9185, 4-slots Ethernet châssis. I saw that cDAQ-9178, 8-slots USB châssis, is recommended for that.
Thank is advance for your replies,
James
(1,476 Views)
If you are referring to the NI 9266 Calibration Procedure, I don't see why cDAQ-9185 won't work. You are calibrating the module but not the chassis. Both Ethernet and USB chassis use DAQmx driver.
https://tmesystems.net/
(1,430 Views)
Hello all,
Yes Zyong, this is this procedure. It is mentionned on page 4 at paragraph "Initial Setup" at step 3 "Insert the module in slot 8 of the cDAQ-9178 chassis. Leave slots 1 through 7 of the cDAQ-9178 chassis empty.".
But in cDAQ-9185 chassis, there are only 4 slots. There is no slot 8.
Which cDAQ-9185 slot should I consider for calibrating my NI-9266 module?
Thanks in advance for your replies
James
(1,381 Views)
