NI-9266
Hello everybody,
I would like to purchase a NI-9266 Module Serie C. How this module is connected with the control PC? Is it possible to control another module? In a frame where both of the modules will be plugged?
Thanks in advance, for your replies.
James
(971 Views)
You need a CompactDAQ chassis.  Look here: https://www.ni.com/en-us/shop/category/compactdaq-chassis.html?productId=118191.  Once you have a chassis that you want, you can just use DAQmx to control your modules.
(964 Views)
Thank you crossrulz
(958 Views)
