NI 9485 8-Channel relay status
In my program, I would set the relays in the 9485 on/off.  Is there a way to check for the status of the relay programmatically to make sure that the relay is health and actually set?  Thanks!
Kudos and Accepted as Solution are welcome!
(3,772 Views)
I'm notice to Labview, how did you activate output relay. I have Labview 2012 and after core 1&2 , it's no easy . Do you have an example for me.
Best regards
(3,765 Views)
Hi jyang7221,
I found this article which I think that it will help you.
Best,
Carmen C.
(3,759 Views)
