01-16-2017
09:31 AM
- last edited on
08-26-2026
11:11 AM
by
Content Cleaner
Hi , i am a new member in NI-COMMUNITY and im planning to buy a NI DAQ PCIe-6321 X-Serie device from : https://www.ni.com/en/shop/hardware/voltage/model-pcie-6321 . I'm wondering if they Offer with this card the BNC connector or not, and if not which one should I buy: BNC 2100 or BNC 2110
thanks in advance.
Solved! Go to Solution.
01-16-2017
09:39 AM
- last edited on
08-26-2026
11:12 AM
by
Content Cleaner
Due to size the BNCs have to be on a separate accessory. I'd have to look at the two BNC accessories to decide which to use, but there's also the USB BNC versions like the 6341: https://www.ni.com/en/shop/hardware/voltage/model-usb-6341
01-16-2017
09:48 AM
- last edited on
08-26-2026
11:12 AM
by
Content Cleaner
By hitting the "Change Accessories" button on the 6321 page you can see all the accessories that are supported. For BNC, there is the 2110, 2111, 2120 and 2090A(which is a server rack mount option if you need that) options. Here are their pages to look at what signals they expose and the connectivity. (some are all BNC, some have screw terminals for non-analog signals, etc)
https://www.ni.com/en/shop/hardware/connectors/model-bnc-2110
https://www.ni.com/en/search.html?pg=1&ps=10&q=779347-01
https://www.ni.com/en/shop/hardware/connectors/model-bnc-2120
https://www.ni.com/en/shop/hardware/connectors/model-bnc-2090a
01-16-2017 10:00 AM
OK thank you so much for the help , appreciate bro 🙂
