NI DAQ 6368 Waveform Characteristics
Hi All,
Here is my question related to NI DAQ 6368 PXIe Card :
Can I use NI 6368 and generate sine wave or triangular wave ? What is the minimum frequency waveform it can generate if it is possible. I'm planning to use this card in NI STS tester with Labview and TestStand softwares installed. Please help to clear my doubt.
Thanks & Regards,
Pramod
(4,359 Views)
The sample rate is clearly stated in that document. Since it appears you don't have an electronics background, you might want to do some basic research on sampling theory and the Nyquist criteria.
(4,355 Views)
