05-13-2019 02:56 AM
Hello everyone,
i installed the tool NI-DAQmx 19.0 to use the device USB-6001 with OTX.studio.
Now I want to know which DLLs and functions of NI-DAQmx 19.0 can be used, which can be also called via OTX, so that I can read for example an ECU voltage.
Thanks for your help.
05-21-2019
09:58 AM
- last edited on
10-20-2025
12:57 PM
by
Content Cleaner
Hi mbour,
at first the integration of the NI-DAQmx into OTX driver happens through the DAQmx C-API.
The DAQmx C-API is integrated by using the header file and library supplied in your National Instruments NI-DAQ installation folder:
e.g.: C:\Program Files (x86)\National Instruments\NI-DAQ\DAQmx ANSI C Dev
You have two options to use this library:
For further information on how DAQmx is integrated in OTX, please reach out to Softing directly.
I hope this helps you.
Best regards
