NI-DAQassistant not detecting the system configuration
I have a laptop using DAQcard-6036E and BNC-2110
yesterday, I just installed labview 8.6.1 but there are some previous versions of labview software,
and then I was simply trying to get the input voltage using DAQassistant and
on the last windown where it's saying "Reading system configuration.. please wait"
message just stayed forever,   one of my friend said try to remove all of labview stuff and
re-install the newest version only, so I did that,
but I get the same problem,
Could you help me on this?
Thank you
(4,208 Views)
Hi Johnny,
Driver software installed before upgrading LabVIEW doesn't get transferred to the most recent install of LabVIEW. I recommend reinstalling the drivers after you have upgraded
Glenn
Glenn
(4,199 Views)
Hi I am having the same problem, I was wondering if you ever figured it out? I have the latest drivers so that is not the problem
(3,643 Views)
Luksudman,
It looks like no one has responded to this forum post in a long time. We have many frequent users who respond to posts with higher visibility, so I recommend you create a new forum post as that will be much more likely to get a response. Please provide as much information as you can about your current system configuraiton, including cards you are using and versions of your operating system and all software.
Best,
Daniel
(3,629 Views)
