NI-DAQmx 8.8 + Borland
About DAQmx 8.8, could you post the lib file to develop with Borland tools (Delphi/C++Builder).
Thanks.
(3,110 Views)
For the moment, NI DAQmx 8.8 doesn't support Borland Delphi. You need to have the 8.6 version. Have a look to this KB, you will find the DAQmx.lib file and some explanation.
How Can I Use The NI-DAQmx ANSI C Function Library With Borland C and Delphi?
Regards
Yann C.
France
(3,096 Views)
I use a PCIe-6535 that is only support by DAQmx 8.8.
So, could you generate the lib file for Borland tools ?
Why don't you provide the file with the DAQmx package as you do for Microsoft C++ ?
(3,092 Views)
