NI-DAQmx Driver installation for NI 6533X
Hi
When windows XP detects the card and installs the driver the installation hangs in the middle of the process.
Reinstall windows but still having the same problem.
Please help
(2,810 Views)
edTyco,
What is the process of installation that you went through? Did you install the DAQmx drivers, then shutdown and install the hardware before rebooting?
What version of the DAQmx drivers do you have on your system? Also, is this Windows XP 32 or 64-bit version?
Hopefully we can get this worked out soon.
Timothy
Timothy S.
Senior Technical Support Engineer
(2,785 Views)
