NI-DAQmx Error Modul_ad.c
Hello all,
I'm trying to record an acoustic signal in Dasylab 10.0.1 with the NI-DAQmx 6210.
System: Windows XP SP3
Board: NI-DAQmx 6210 with USB
MAX configuration:
Sampling rate: 32768
Samples: 32768
Connection: RSE
After an hour I received an error message:
NI-DAQmx Analog Input: AnalogIN_0-3
file: Modul_ad.c, row:2205
I already deleted the old and created a new task, but it didn't change anything. In addition I already tried to set the configurations back to factory settings and start up new.
Does anyone have the same problem or an idea to solve it?
Lars
(5,125 Views)
here is Dominik from the AE's in Munich.
At first i want to know what DAQmx driver version you use. You can find the version in your MAX (Measurement & Automation Explorer).
Perhaps you can add a screenshot of your error message.
Thank you
Best regards
Dominik
(5,099 Views)
Hello Dominik,
thanks for you reply. I'm useing the DAQmx 8.6.0f6 driver version. In addition I added an screenshot of the error message.
Best regards from Dortmund,
Lars
(5,097 Views)
Hello Lars,
I found out that the USB-6210 needs the DAQmx 9.6 driver.
Perhaps the problem is caused by the driver. Please try to deinstall your driver first then download the new driver and install it.
You can find the DAQmx 9.6 here :
NI-DAQmx 9.6 - Windows 7 64-bit/7 32-bit/Vista 64-bit/Vista 32-bit/XP 32-bit/Server 2008 R2 64-bit/Server 2003 R2 32-bit
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288357
I hope it solves your problem.
Best regards
Dominik
(5,095 Views)
Hello Dominik,
Sorry for late reply.
Finally I bought a new PC and updated the driver and software to the current version.
Thanks for you help and best regards,
Lars
(4,819 Views)
