NI-DAQmx .NET Framework 3.5 Help missing
 Hi, I have installed the DAQmx 9.2.1 DVD software.
The help file:
has a broken link.
I found this document:
http://digital.ni.com/public.nsf/allkb/6C61B11A7955517D862576DB005F7571
but Windows doesn't accept the new link that you suggest.
Any help please?
Thank you very much
(4,102 Views)
Hello Roberto,
can you please take a look at the following forum?
I believe it describes your problem and contains a solution.
http://forums.ni.com/t5/Measurement-Studio-for-NET/Help-2-isn-t-included-with-VS2010/m-p/1412660#M10...
Antonios
(4,098 Views)
Thank you Antonios, I am downloading the 9.2.3 package and will let you know if this helps.
(4,094 Views)
I have installed DAQ MX 9.2.3.
The link to "NI-DAQmx .NET Framework 3.5 Help" is still broken,
while if I double click the file "NI-DAQmx .NET Framework 4.0 Help" it opens a page in Explorer saying it can't open the file.
So I have done what is written in that topic:
"In Visual Studio go to Help>>Manage Help Settings>>Install content from disk, then browse to C:\Program Files\National Instruments\MeasurementStudio2010\Help and select the .msha files. This will integrate the DAQmx Help into Visual Studio Help."
But I can't find any msha file from Visual Studio browse Windows.
Any hint?
Thank you
(4,081 Views)
