NI-DAQmx installation fail: NIMDFBINDIR is undefined
My installation o f NI-DAQmx fails with the following message
Fatal Error!! Required NIPathsDir property NIMDFBINDIR is undefined.
I have tried 9.8.0 and 14.5, both have the same issue.
Running 32 bit Windows 7
Ideas?
(4,587 Views)
It seems I get different ones for other versions. For NI-DAQmx 9.2.2 I get
MAXAFWDIR is undefined.
(4,572 Views)
Hi Roland,
This error may occur if you move or delete "My documents" or "My Picture" folders. National Instruments installers require the existence of a 'My Documents' and/or a 'My Pictures' folders. Check that these two folders are there.
Scott B.
AE NI
(4,548 Views)
It worked!
Thank you so much. For those who have the same issue, restoring the user folders in windows 7 is described here
(4,475 Views)
