NI Daq 6008 and Labview
hello;
For the NI 6008 card sampling frequency equal to 10 kS / s and it has 8 analog inputs, but if I will use the 8 analog inputs simultaneously, what is the value of the new échantionnage frequency for each input analog obtained during an acquisition in labview?
(6,686 Views)
From what I can gather from the data sheet, each channel will be sampled at the 10kS/s.
(6,660 Views)
Thank you for the answer, but according to the datasheet, the 8 analog inputs have a single ADC and a multiplexer connected before to the ADC allows the passage of all analog signals, so I don't know if 10 KS / s is achieved in all inputs when used simultaneously !!
(6,658 Views)
The data sheet also says the maximum sample rate for multiple channels is 10kS/s aggegate.  I take this to mean that the entire channel sweep is done at 10kHz.
You could always try it and see what happens.  Read all 8 channels as a waveform with the sample rate set to 10KHz and see what the dt is in the waveform.
(6,638 Views)
The maximum sample rate per channel is the aggregate rate divided by the number of channels.
(6,628 Views)
Thank you for your answer, but  the 10 KS / s given in the datasheet of the card NI 6008, is it the maximum sample rate per channel or the aggregate rate ?
(6,621 Views)
The manual clearly states what the aggregate sample rate as already mentioned. It is 10 KS/s just to remind you.
(6,599 Views)
