NI Daq Task not working
I have created a daq-Task in MAX but It's not showing the digital signal. But in the Max-Test-Panel it shows? Whats my error?
Here is the test-Panel, line 1 and 3 are active
But the task shows nothing, no active line
Thanks for help
(867 Views)
You have selected a single sample mode on demand. IIRC, by default, from this interface it will only write 0. You can enable continuous generation and you will see the test data on the oscilloscope:
(806 Views)
