NI ENET-9163 Initial Config
How do I perform initial config of a NI ENET-9163, when i don't have a DHCP server, or how do I reset IP address if I loose it?
Best Regards
António Cardoso
(3,227 Views)
 Hi acardoso,
You don't need to know the ip address of your device, in  Measurement & Automation (MAX) you can see the ENET-9163. Just click on Network Config tab and you will be able to change the IP address.
Best regards.
(3,181 Views)
