NI-MAX and custom scale
Using a NI 9209 to measure voltage which represents pressure.
Voltage should be between 0 and 5.
Pressure is between 0 and 200.
I created a Custom Scale in NI-MAX where slope m = 200/3.52 and b = -176/3.52
I created a Task in NI-MAX to use the custom scale.
When viewing the Task, what should I have as values in the Signal Input Range's Min and Max boxes?  I have Min = 0 and Max = 200.
(2,418 Views)
Have you already read this thread?
DAQmx custom scale: how do you set MIN and MAX values?
Certified LabVIEW Developer
GCentral
(2,400 Views)
The Max and Min are to match your pressure.  In other words, the Max and Min should be values AFTER the scale has been applied.
(2,397 Views)
