NI MAX can't launch in Win10 (Daq-mx driver)
Dear NI,
I have a rather difficult problem to solve with NI Daq-mx software.
On a PC with Win7 the NI Daq-mx software (version 15.0) was installed without problems:
it is necessary to use the cDaq-9181.
The big problem is this one: in a new PC with Win10 Pro we installed the version
17.6 of the NI Daq-mx (told compatible with Win10).
The installation finishes smoothly but, when we try to launch NImax.exe,
it appears the following error window:
"The application was unable to start correctly (0xc000007b).
Click OK to close the application".
I tried many solutions watched in the Net but without success:
the problem is rather frustrating.
Could someone suggest me some procedures to try?
Thanks for the attention.
(3,085 Views)
At the end I found a working solution:
I uninstalled all the National software in the PC and I reinstalled the version 15.5
of the Daq-mx driver in the proposed folder.
The release 15.5 of the driver is the first to be cronologically compatible with Win10:
with the goal of a basic usage it seems enough to stay with that version.
I could open MAX and read the signals coming from the Cdaq board.
(3,004 Views)
