NI-Max Error Message: Sample Clock Timing Error
We have a cDAQ chassis 9136 with the embedded processor. We primarily use 9237 strain modules in it. However, we have purchased a sensor that not only has a strain gauge but also and XYZ accelerometer in it.  On the advice of the sensor manufacturer we purchased 9205 modules to measure the single ended measurements for this sensor. When we tried to setup the task in NI-MAX we get and error message stating the we need to set the Sample Clock Rate. I have attached a photo of the error message. Is there a work around for this?
Message 1 of 1
(926 Views)
