NI PCI-6013 and Windows XPE
We are porting our project to XPE on a diskless system.
We were told that NI does not support that directly (is that true ?).
We would need to create a Target Designer component for this module.
I am looking for a plug and play (.inf stype) driver installer or else for instruction on how to do installl the driver manually.
Using the .exe installer provided with the board is not acceptable in our environment because of the footprint. We even experienced an installation failure possibly due to the type of non volatile media (a standard CF card  that appears a removable drive).
Please help us.
Saluti.
(3,313 Views)
Yes it is right, NI does not support Windows XP Embedded. This does not necessarily mean a DAQ Board or Driver won't work on a WinXP Embedded machine. It does mean that there is no support for this specific operating system.
Would realtime be an option for you?
AlessioD
(3,298 Views)
>NI does not support Windows XP Embedded. This does not necessarily mean a DAQ Board or Driver....
It would suffice to discover how to install the driver manually and assign configuration data without using MAX.
No, our project is tied to Windows.
Saluti.
(3,293 Views)
