NI PCI 6259 Number of Analog Output Channels
Hi.
I have NI PCI 6259 connected to BNC 2110. I need to use 4 analog output channels. Only two (AO0, AO1) are working. What should I do to use the other two?
I tested generating DC signal with a simple labview VI, and also with NI MAX. The output voltage of AO2, AO3 were zero. The switches on the BNC terminal block were on FS.
(2,292 Views)
I don't have a 6259/2110 however a quick RTFM show that AO3&4 are located on the second 68 pin connector-1 and I assume that you use one 2110 with one 68pin cable (SHC68-C68-EPM ??) .. connected to connector-0.
So you might need a second 2110 and another cable? (Check what you need... I would simply call NI;) )
Greetings from Germany
Henrik
LV since v3.1
(2,261 Views)
