NI PCI-6703 under Simulink
In order to develop a HIL (Hardware in the Loop) and SIL (Software in theloop) simulation test bed, I am using a NI PCI-6703 and a NI PCI-6220. I am having some trouble at themoment getting to work these cards in Simulink, Matlab. I wanted to know if you could help me, whilesending a similar example where one of these cards are used inside Simulink, or a guide with the steps to follow.
(3,626 Views)
Hi Gasca,
I had your post moved from the DAQ Idea Exchange to the Multifunction DAQ forum--we'd like to keep the Idea Exchange reserved for product suggestions rather than for specific support requests.
To use these boards in Simulink you will need to obtain the Data Acquisition Toolbox from The MathWorks.  Both the 6220 and the 6703 should be supported in the most recent version of the toolbox.  The Data Acquisition Toolbox is not directly developed or supported by NI.
Best Regards,
John Passiak
(3,609 Views)
