NI PCI-6713 not listed in NiDAQmx 8.7
I have NI PCI-6713 card and a NI BNC2110 accessory connected to it.
Measurement and automation explorer version 4.5 and NIDAQ8.7 are installed alongwith LabVIEW 8.6.
MAX does not list PCI-6713 card under NiDAQmx, but it lists under PXI as [PXI6::2::NI PCI6713] and a chassis file is required.
i do not know how to configure BNC2110 with NI PCI-6713 under these circumstances as i am not using any chassis to mount the PCI-6713 .
PCI-6713 is mounted in one of the CPU slots.
Also the instrument input/output assistant dispalys that no physical channels are available, when i create a task to create an analog output.
Kindly suggest me what should i do.............
Kindly reply and ask if i need to specify more details.
regards,
ketan.
Laser Lab
Department of Physics
Indian Institute of Science.
Bangalore-560012
INDIA.
Message 1 of 1
(3,279 Views)
