NI PCI 6733 anlog out put card
Hi Baron,
Thanks for the respond.
Baron Q1 :- I don't understand what you are refering to by "CCA" and the "CosMos system".
Aro A1 :- CCA stand for Circuit Card Assembly and CosMos refer to Control Loading and Motion System.
Baron Q2 :-Also, would you please clarify what you mean with your naming convention for slots (B/B, A/B, B/A, A/A).
Aro A1 :- This refer to the pin slot at Mother Board.
Baron ,
We measure the Voltage pin 6 and 7 at the PCI slot with  Ref to Computer Chasis.
We feel doubt  may be output Voltage from our PCI slot cause our AO CCA defective.
Baron ,
Can you explain briefly signal at this pin
Pin 6 -> PFI 5/AO SAMP CLK       Pin 40 -> CTR 1 out.
Pin 7 -> Digital Ground                  Pin 41 -> PFI 4/ CTR 1 Gate.
Thanks in advance
Aro
:mansad:
Message 11 of 14
(1,149 Views)
If you want someone to look at images, linking them to your c drive is not the way to do that. Use the 'Add Attachments' or click on the 'Upload or insert an image' button.
Message 12 of 14
(1,141 Views)
Hi Aro,
The signals on those pins are as follows:
Pin 6: This pin can be used as either an input Programmable Function Interface (PFI) line or to output the Analog Output Sample Clock signal (ao/SampleClock).
Pin 7: This pin is Digital Ground which acts as a reference for the digital signals at the I/O connector as well as the +5 VDC supply.
Pin 40: This pin is the output of Counter 1. It emits the Ctr1InternalOutput signal.
Pin 41: This pin can be used as either a Programmable Function Interface (PFI) line or to output the Gate signal from Counter 1 (Ctr1Gate).
You can find all of this information in the Analog Output Series User Manual.
Barron
Applications Engineering
Message 13 of 14
(1,121 Views)
Hi Baron,
Thanks for the info.
your info is a great help
Thanks again
Aro
Message 14 of 14
(1,098 Views)
