NI R Series Multifunction RIO Problem
Basically, I am trying to acquire some data using the DAQ and transmitting it to another terminal through the ethernet. I am wondering if the NI R Series Multifunction RIO supports the ethernet transmission? If not, what other communication modules can I interface with the NI R Series Multifunction RIO to achieve it.
Thanks in advance.
(3,205 Views)
Since ethernet signal level is not TTL, this is not possible.
What you should do is to send a data back to PC host, and communicate with another device via host ethernet.
(3,182 Views)
