NI-Scope NI 5102 Timeout
I am using a NI-Scope card NI5102 to aquire pulses, and therfore using edge
trigger. I periods were ther are no pulses I want to acuire the noise. This
can be done by changing the triggering mode by the software, an it works
fine. The problem is the transition from edge triggering to direct trigering
takes to long time 2,5seconds. When in edge triggering mode I use the status
VI to check if the aquisition has finished and it seems that this VI waits
in 2,5 seconds before it return a status when there is no trigger. Can this
wait/timeout be set?? I am using IVI drivers and I do not find were to set
timeout values!
Regards
Hans Øhra
hans.ohra@ffi.no
Message 1 of 1
(2,989 Views)
