NI TESTSCALE TS-15010 Fan-Speed adjustment
Hello community,
I installed TS-15010 backplane together with several I/O modules at 19 inch rack together with driver NI DAQmx 24.0 and started configuration with NI MAX.
The specification of TS-15010 show following:
"Forced air circulation (positive pressurization) through three 169 cfm fans with High/Auto speed selector"
https://www.ni.com/docs/de-DE/bundle/ts-15010-specs/page/specs.html
In Factory Setting the fan works in "High"-Mode which is very noisy, it is not possible to work in same area together with the Test Scale device.
My intention is to adjust the fan setting to "Auto"-Mode but I cannot find the setting in NI MAX and even not in "Utility Tool Hardware Configuration".
Simple question: How can I change the fan speed setting from "High" to "Auto" for NI TS-15010?
Thanks in advance for support.
-maphan
Message 1 of 1
(484 Views)
