01-22-2021 08:28 AM
Hello i have one NI-6001
I would try to connect an encoder with the following cable to the instrument how can i proceed:
A red cable
B orange cable
/A yellow
/B green
GND black
5 V brown
regards
01-24-2021
07:13 PM
- last edited on
12-08-2025
10:57 AM
by
Content Cleaner
You can try to refer to the links below on how to connect to an encoder and related information.
Since you mentioned about connecting to an encoder, you might need to be aware that USB-6001 has only 1 counter which could only count edges of the encoder pulses and might not be able measuring position.
USB-6001Connection to Digital Encoder - NI Community
NI USB-6001 Specifications - National Instruments
Cheers
01-25-2021 03:03 AM
Hello Thanks for the reply
I have found this.
Do you think that i can use this connection with 6001?
01-25-2021 03:51 AM
I have done this connection
a to pf0 b to pf1
But i have no signal
Do you think that with the USB 6210 i can red the encoder?
01-25-2021
07:46 PM
- last edited on
12-08-2025
10:58 AM
by
Content Cleaner
Sorry for the late reply.
Seems like you managed to get the connections in.
Yes, it is possible to use UBB 6210 as it has two counters.
You can check out the manual in the link below for references.
USB-6210 Specifications - National Instruments (ni.com)
USB-621x Manual - National Instruments
USB-6210 Quadrature encoder hookup - NI Community
Best Regards.
