NI USB-6001 Digital Input - Will Leakage current contribute Significantly
Greetings,
The USB-6001 Specifications manual states that the maximum input leakage current of digital input are 0.8mA(@3.3V) and 4.5mA(@5V).
Are these values typically observed? What are the typical values?
I would like to connect a voltage divider with 1000:3800 ohms (R1, R2) powered by 24V such that 24V*R1/(R1+R2) = 5V input is fed into the digital inputs. The current flowing through such a voltage divider will ideally be 24/4800 = 5mA if input leakage current = 0.
Since the maximum input leakage current are mentioned to be as 4.5mA@5V I am worried whether this would cause any issues.
I would also like to know about the input-impedance of digital input of USB-6001
Message 1 of 1
(1,051 Views)
