NI USB 6008 and Pressure Regulator
Hello everyone,
I would like to control this pressure regulator: http://www.parker.com/literature/Literature%20Files/pneumatic/Literature/PDN1000US_Products/PDN1000-...
The specifications are: Analog Control 0 -10V ; OutPut signal: Digital PNP or Analog 1-10V or 4-20 mA.
I want to use the USB-6008 but i saw that it can only supply 0-5V analog signal. Is it possible to get a higher voltage? And is it good enough to acquire the signal?
Thank you for your help and happy holidays!
Ilan
(4,638 Views)
Anyone?
(4,610 Views)
Hi Drops,
The USB-6008 can only output 0-5V.  You could use a simple op-amp circuit to scale this up to 0-10V, though.
The output of this regulator seems to be a 24V digital signal.  This is standard for industrial applications.  The USB-6008, however, is only rated to recieve a maximum of 5.8V for digital signals.  You could also get around this with an op-amp (or a comparator for that matter).
I hope thsi helps,
-Jim
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(4,537 Views)
