NI USB-6009 Data Acquisition (DAQ)
I am currently working on a project that involves acquiring data from sensors using the NI USB-6009 Data Acquisition (DAQ) device. Specifically, I am interested in interfacing with both accelerometer and microphone sensors for measuring vibration and sound pressure, respectively.
Before proceeding further, I would like to inquire about the compatibility of the NI USB-6009 DAQ device with both accelerometer sensors requiring IEPE excitation and microphone sensors. Could you please confirm whether the NI USB-6009 supports IEPE excitation for accelerometer sensors and whether it is compatible with microphone sensors?
(1,449 Views)
Unfortunately, USB-6009 cannot provide IEPE excitation.
You would need a Sound and Vibration module.
Measuring Sound with Microphones
Sound and Vibration Bundle
https://tmesystems.net/
(1,430 Views)
I use a USB-4361 for accelerometers and force hammers all of the time.  They provide the IEPE current source. Unfortunately they are not cheap like the USB-6009.
For $600 you can get a signal conditioner that turns the IEPE (ICP) accelerometer to a voltage signal.
https://www.pcb.com/products?m=482c05
They also make similar products in different packages.
https://www.ni.com/en-us/shop/category/sound-and-vibration.html?page=1&foc=0
I am not sure what the microphone requires.
This might do what you need for $100.  I make no promise of the quality, etc.
https://www.aliexpress.us/item/3256803038785547.html?spm=a2g0o.detail.0.0.2f347e9fwD8vVp&mp=1&gatewa...
(1,369 Views)
If you're budget-constrained, these are some alternatives,
https://digilent.com/shop/mcc-webdaq-504-internet-enabled-vibration-acoustic-data-logger/
https://digilent.com/shop/mcc-dt9837-series-dynamic-signal-analyzers/
Santhosh
Soliton Technologies
(1,364 Views)
