NI USB 6221 Not detected at XP startup
hi,
Got a USB6221 which works briliantly.
The problems is I have to either power cycle the device or remove and re-insert the USB cable to get the device detected when I start windows XP.
Looking at the Device Manager, the action mentioned above kicks off "Data Acquisition Devices" and there are no further problems....until I switch off the pc and startup the following morning!
Incidently, "Data Acquisition Devices" are automatically detected on a PXI system with a built in controller.
Has anybody else had this problem?  Can anybody offer a solution?
Thanks in advance.
Dave
Message 1 of 8
(5,087 Views)
Hi Dave,
I've had a search for previously reported issues of a similar nature and found a common factor of this problem being associated with the BIOS needing to be updated, and particularly connected to HP and Compaq computers. What exactly make/model is your PC/laptop?
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
Message 2 of 8
(5,060 Views)
Accepted by topic author sladed
What version of DAQmx do you have? We resolved a similar issue in DAQmx 9.0.2.
Andrew S
Message 3 of 8
(5,058 Views)
Andrew/Imtiaz,
Thanks for the response chaps.
Downloaded the latest version of Daqmx: problem fixed.
Incidently, my pc is an HP.
Much appreciated.
Dave
Message 4 of 8
(5,032 Views)
Cheers Imtiaz,
PC is HP.  Fixed the problem with the latest version of DAQMX.
Dave
Message 5 of 8
(5,028 Views)
Andrew,
Spot on!
My version of DAQMX was 8.6; download the latest version and the problem is fixed.
Dave
Message 6 of 8
(5,026 Views)
Hi Dave,
Glad to hear the problem is resolved!
Imtiaz Chowdhury
Project Manager
Message 7 of 8
(5,016 Views)
I am having a similar issue.With a PCI-6221 & PCI-4462
XP can see my cards, but I cannot initialize them in LV!
I can see the cards in Device Mgr, as well as in NI-MAX.  However, on a difference PC in our factory (different cards as well) the info displayed in MAX is different.
I thought this might be because I am using NI-DAQmx 9.4 (I tried updating from 9.3.5), where the factory is using version 8.x
I am using a Dell, running XP.
Any help would be appreciated.
Message 8 of 8
(4,042 Views)
